Josh_Quant 27 Posted April 19, 2016 Can any recommend best place to buy 405 window switches that light? Share this post Link to post Share on other sites
calvinhorse 870 Posted April 19, 2016 Paul Higgs aka 205turbo does them I think.. Desboroughdesigns? Share this post Link to post Share on other sites
calvinhorse 870 Posted April 19, 2016 Ahhh sorry it's 205/309 not sure if they're the same http://www.desboroughdesigns.co.uk/#!product-page/ccq7/8b0a3372-75c0-96de-d3ab-9c501050a315 Share this post Link to post Share on other sites
welshpug 1,670 Posted April 19, 2016 405 ones have a longer top rocker, but that can be swapped for a 205 unit. or swap the bulb holder over, you could modify them yourself with a low wattage led even, just needs to be connected to the switched live feed and the earth pin. Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted April 19, 2016 I got some from Paul (205turbo), they were for a 106, just swapped the tops over. The only other thing i had to do was to file a small plastic ridge off each side as they wouldn't quite squeeze into the 205 holder. Share this post Link to post Share on other sites
Josh_Quant 27 Posted April 20, 2016 Was that new from Paul? Share this post Link to post Share on other sites
timoth123 37 1 Cars Posted April 23, 2016 As J turnell said. You need to file a little tab off. Also, it only lights up one of the arrows in green. I'm sure the older 405 ones light up both arrows in a pale orange/ white light Share this post Link to post Share on other sites
