K20205 5 Posted April 8, 2016 (edited) Hello everyone im new to the forum and would like to share my build with you guys, Im in the middle of building my first 205 with a honda k20 engine. Im slowly going to upload pictures of my build thread as i work on the car only couple days of the week and only a few hours, slow but worth everything. Hope you enjoy. ???? Edited April 8, 2016 by K20205 Share this post Link to post Share on other sites
K20205 5 Posted April 8, 2016 Hello everyone im new to the forum and would like to share my build with you guys, Im in the middle of building my first 205 with a honda k20 engine. Im slowly going to upload pictures of my build thread as i work on the car only couple days of the week and only a few hours, slow but worth everything. Hope you enjoy. ???? Share this post Link to post Share on other sites
K20205 5 Posted April 8, 2016 These are the only pictures i have so far, most are on my old phone. Various radiators test fitted for bonnet and front panel clearance. Ended up using the ep3 radiator because all the hoses fit without fiddling around. The driveshafts angle looking fine. Redesigning the gearbox side mount, made a template and going to construct a solid mount Throttle cable and pedal from a 1997 civic hatch fitted 1 Share this post Link to post Share on other sites
allye 530 3 Cars Posted April 8, 2016 Amazing! What are the shafts? Honda inner and Peugeot outer? Share this post Link to post Share on other sites
K20205 5 Posted April 8, 2016 Yes its honda inners and peugoet outers but its just been welded together for measuring purposes, im going to get some made. Share this post Link to post Share on other sites
DBG 16 Posted April 8, 2016 Looks like it fits nicely. Thanks for sharing, looking forward to seeing progress! Share this post Link to post Share on other sites
DC2T 51 Posted April 9, 2016 Looks promising, thats whats going into mine also so will be watching this closely Share this post Link to post Share on other sites
K20205 5 Posted April 9, 2016 I have managed to source more pictures from my friends mobile, These where taken at the early stages of the build. Share this post Link to post Share on other sites
K20205 5 Posted April 9, 2016 Replaced the big end bearings on the k20 because mileage is on 167k lol. Standing waiting for its new home IN! But not sp smoothly. Gearbox diff end touching the subframe so i had to grind the subframe to free up some space. Fabricating the gearbox side mount. Heres the result so far, not happy with it may redesign it at a later stage. Using the ep3 clutch cylinder i made it fit the 205s clutch pedal with a few modifications. . . More pictures are coming soon, need to find my old phone and upload to my laptop. Share this post Link to post Share on other sites
DC2T 51 Posted April 9, 2016 Thats alot to come out of the subframe Share this post Link to post Share on other sites
DBG 16 Posted April 9, 2016 It may just be the angle of the last pic, but how much clearance is there under the sump? Share this post Link to post Share on other sites
K20205 5 Posted April 10, 2016 I had no other option, unless i wanted the driveshafts to sit at an angle, This way the engine is perfectly level with the hubs. I have reinforced it with thick metal so i hope it wont affect anything with the driveshaft. Share this post Link to post Share on other sites
K20205 5 Posted April 10, 2016 It may just be the angle of the last pic, but how much clearance is there under the sump? Now with the new mount setup it has about 10-15cm off the ground clearance.. A k20 ek or eg civic has alot more lower clearance than that. K20 engines are quite long. 1 Share this post Link to post Share on other sites
DC2T 51 Posted April 10, 2016 seeing this is making me think i should stick with fitting my B18 instead. What engine mounts etc is it youre using for the rubbers? Share this post Link to post Share on other sites
K20205 5 Posted April 10, 2016 seeing this is making me think i should stick with fitting my B18 instead. What engine mounts etc is it youre using for the rubbers? B18 will be alot easier, but for the gearshift linkage im not sure. The mounts are from ford capri mk1 rear leaf springs, i bought the tube and bush kit from ebay for around 30. Share this post Link to post Share on other sites
DC2T 51 Posted April 10, 2016 ill have to have a think then as ive got both engines, ill have a proper look at some point. K20 is definately the better one but i love the sound of the B18 Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted April 10, 2016 I do like the idea of a V-tec 205. Are you going for throttle bodies and management? Share this post Link to post Share on other sites
K20205 5 Posted April 10, 2016 ill have to have a think then as ive got both engines, ill have a proper look at some point. K20 is definately the better one but i love the sound of the B18 Ill go for the k20, youve got the extra gear plus its easier to tune and gain power out of. I got a b20vtec ek and the crossover is leathal.. Share this post Link to post Share on other sites
K20205 5 Posted April 10, 2016 I do like the idea of a V-tec 205. Are you going for throttle bodies and management? Ill be driving it on stock managment for now, Im planning of turboing it next year sometime with hondata managment. Share this post Link to post Share on other sites
DC2T 51 Posted April 10, 2016 Ill go for the k20, youve got the extra gear plus its easier to tune and gain power out of. I got a b20vtec ek and the crossover is leathal.. im swapping a c4 turbo into my teg and have the engine spare which was my first thought. Love the b series crossover Share this post Link to post Share on other sites
petert 607 Posted April 11, 2016 I have a friend who races a N/A Civic. It has a K20 head on a K24 block. The thing is mind blowingly fast for an otherwise standard engine. Search on FB for BYP Racing Budget Honda Civic. Share this post Link to post Share on other sites
