pedjoni
205 1.6 Gti, Hot Start Problem?
pedjoni
when its cold the car usually starts on the button without any problems, if I take it for a good run, switch it off and then give it a min or so it still fires up without hesitation.
if I leave it for say 5-10 mins or so, its turning over for 5,6 seconds and then start... Does anyone had this problem ???
erbs
could be fuel pump, i had this problem,changed pump for a new bosch and now starts everytime on the button. that was my symptons on the car,pump getting weak
pedjoni
if it is pump, it is very exprensive ! here is 300 euros new, bosch.. did your car , run beter when you changed pump?
Edited by pedjoni
pedjoni
Can someone tell me , where is fuel pump relay located ? I ve changed Coolant temp sensor, situation is the same.. Today I must check fuel pump, and relay?
Weser
Next to the ECU in top of the drivers side little storage gap which is below and to the right of the steering wheel. But that is in a UK RHD car.
pedjoni
Does anybody know, fuel pump from 1.9 gti is it the same like and 1.6 gti ? visualy they are same , but i don t know about pressure?
Yes, fuel pumps are the same for 1.6 and 1.9 GTi models of a given age. Fuel pressure is set by the fuel pressure regulator, and again, is the same on both - 3.0 bar.
pedjoni
Great , I have spare original fuel pump from 1.9 gti, so I will try. Thanks
pedjoni
I think I fixed my hot start problem... I ve changed Fuel Pressure regulator and fuel pump yesterday. For now everything seems more than ok... Car starts everytime as soon as I move the key. Also I noticed that car now runs much better when it is warmed up, so I am suspecting that fueal pump was the problem ...
pedjoni
I am afraid I did not solve my hot start problem... It is now the same like and before... When it happens , and car starts i can smell gasoline very strong after it starts... So i ve changed fuel pump, FPR, check for vacuum leaks. I am very frustated with this problem... It makes me nervous, I dont know what to do anymore ??? o.O
estland
When idling are the revs bouncing too and engine wants to stall? I had same issue with air flow meter (wiper track worn)
pedjoni
No , I don t have that symptoms ...
pedjoni
Finaly , problem is solved. Replacement FPR which I ve changed I found da he is bad. Changed him and car now starts everytime on button. :) :) :)
erbs
Fuel Pressure Regulator at fault?
can you still buy these new?
Edited by erbs
pedjoni
I could order it, it was around 220,00 euros in Montenegro. But I had one spare in my garage, I was a bit lucky :)
