Paul_13
A Bit Of Help Needed On An Audi A3 Vreg '8L' Please
Paul_13
This is driving me nuts basically.
I plugged it in to vagcom and no faults showed up apart from temp sensor live short...
The list of faults are all clock related
-temp gauge goes straight to 120'c when you turn the car on and it comes up as overheating. Which is isn't. HG isn't gone.
-fuel gauge has always had a mind of its own.
- now the Rev counter and speedo have been playing real silly buggers recently
20160325_185233_zpsygzgewmu_edit_1459010
That's with the key out of the ignition.
Today I've
- redone all the earths in the engine bay
-cleaned up the positive bar thing on the battery
- put a new coolant temp sensor in today, hasn't fixed the 120'c issue.
Now other option is a new set of clocks, but I've heard rumours you have to reprogram them etc is that Bulls*it or true?
pugdamo
Have you checked the battery, sounds silly but a knackered battery can cause a load of problems. The immobiliser is built into the instrument panel, I found this out after removing the instrument panel to be sent away for repair from an Audi TT and it not starting with it out.
2-Pugs
Battery is a good shout. A few years back the instruments in my Xsara went haywire immediately before the battery died. Worth a try.
I thought there was a known issue with Audi TT instrument binnacle a failing in some way? Could this be a similar thing?
Paul_13
Pretty sure it's not battery related, I put the one out of my 306 in there, still the same
Paul_13
I'll give it another go and let it settle in with a drive maybe
allye
You do have to reprogram new clocks. The girl friends 1.8T has the leaky pixels and I read up on it. £100 to send the cluster off to get repaired.
Edited by allye
