jack-pug
Stub Axle Info
jack-pug
could anybody clarify if this is a 309 GTI stub axle or not, brought a replacement 309 gti one but its longer, not sure which one is correct.
jimmi
A 1900 205 GTI is same as 309 GTI stub pin /axle - approx 132mm long overall. The m22 thread on the end is 22.5mm long. From the end to the shoulder of the plain shank is 127mm long.
Bearing spacer is around 13mm long. Pins are 25mm diameter. Pins for models with drum brakes are shorter.
And
Mite be wrong but that looks like the longer 306 one
Biggles
Can anyone point me to someone who makes these please ? I'm looking for someone to make me some of the corresponding pins for my Visa - they're similar to the 205 ones but in true PSA fashion, not identical (as that would be too easy). I figured someone who makes 205 ones would be a good place to start.
Thanks.
bridgecraft engineering can make you some, they do oversized for the camber altered trailing arms they do.
Biggles
Cheers for that. Will drop them a line.
jord294
Thanks.
Stew Baker @ BakerBM
Biggles
Thanks !
Bridgecraft is the place.
