N3VRAM
Question About Master Cylinders..
N3VRAM
Hi All,
Putting a hydraulic handbrake on the car has made the pedal travel on my peugeot a little ridiculous, i'm thinking if I put a bigger master cylinder on this would probably cure the problem.. my question is can i bolt the master cylinder from a 1.6/1.9 GTI straight onto my 1.4 servo, or would i need to replace that too?
Thanks in advance,
Matt.
you probably still have air in the system, fitting a hydraulic handbrake shouldn't make the pedal any longer.
Standard gti MC is 20.6mm, others are 19mm so you'll have a reasonable decrease in pedal stroke from the extra surface area, though a lower outright clamping force on the pistons, the larger bore unit is otherwise identical
