davey205
Distributor Caps Late 1.6
davey205
I've had a look on servicebox and some car parts websites but the one pictured for the 1.6 is not the one I need, I believe I read on here the later 1.6 ( mines on an H ) were fitted with the same distributor cap as the 1.9.... is this correct?
Forgive me if there are more than 1 type fitted to the 1.9s I will try to describe it as the one with the metal prongs coming out of the cap then female leads with long straight ends.
If anyone has a part number would appreciate.
Also best place to get and is it time to start stocking up on parts like these?
Edited by davey205
What's the dizzy code? If it's a 085 or 085 (which it should be on a late 1.6) then it's the same male Bosch cap as a non-CAT 1.9. This has a screw-on fitting.
Earlier 1.6's (063 dizzy IIRC) use a female cap with a clip-on fitting.
