Juttie205
Reverse Switch Wiring Help
Juttie205
I have just fitted my engine and thought that the wires on the engine loom would go straight onto the switch but switch has 2 spade terminals and i have a 2 pin plug on loom should there be a small loom from switch to plug?
sounds like you have the wrong loom for the switch, or vice-versa, later cars had a JPT plug, earlier ones had a brown two spade plug
Juttie205
thanks mate think ur right will get a different switch must of left my original one in gearbox i sold.
The switch plungers are different lengths so you can't just put a BE3 switch into a BE1 gearbox or vice versa, you'll need to change the plug on the loom.
Juttie205
looks like you can get 2 different lenght ones with connector so will see what one i need as would rather not cut loom.
