Clapton_Is_God
Driveshaft Diff Seals Confusion
Clapton_Is_God
Hello All,
I've just bought some new, supposedly genuine driveshaft seals from a Peugeot parts supplier on eBay. I've received two seals made by Corteco but I'm not sure that they're correct.
Both seals fit into the gearbox/diff housing but both are a very sloppy fit around the shaft, in fact the nearside doesn't touch at all, it's a mile off.
Is that correct and are Corteco genuine parts? Sadly, I threw away the original seals.
I should add that it's a VTS box taking 1.9 shafts.
Corteco part numbers are 20015497B and 20020137B.
Many thanks for any input.
Have you pushed them in flush to the housing, if so that's the problem, God knows why but you are supposed to leave them about 4mm proud.
Also, have you swapped the diff, as the xsara/306 diff takes a shorter inner cv in the NS. Usual fix is to fit the 205 diff case with the xsara crown wheel.
Clapton_Is_God
Hello Tom,
Thanks for the quick reply!
I haven't fitted them at all yet, they looked so sloppy I thought I would check here first.
I have changed over to the 1.9 diff, so hopefully all is well there.
I've used the Conteco ones on eBay before and they've been fine. Not sure off the top of my head if they're the correct part numbers though.
Obviously the flexible inner lip on the seal should form an oil-tight seal around the shaft though, so if it doesn't then something isn't right and it'll leak like a sieve.
Clapton_Is_God
Hello Anthony,
I figured that was correct but wanted to make sure before I sent them back.
Thanks for your help.
toolie72
I tried a few different OE SPEC seals from eBay before I got ones that didn't pee all over the place-when I got the car in '96 that was common too (leak when warm after a run) however you could get Peugeot ones then
Obviously OE SPEC is just 6 letters rather than a truthful description
Send them back and try try again
Remember what Tom said-leave seals proud!!
Ozymandis
I have used corteco, they were fine.
Sounds like fitting issue or wrong assemblage of parts?
Clapton_Is_God
Good point, I've just re-read the eBay listing and although they're listed as genuine parts, in the small print it states they're OE spec.
I contacted them and they are surprised that there is a problem because they say they only stock one seal and it fits 85% of Peugeot models.
Are they no longer available from Peugeot then?
lol
still available from Peugeot, they're still using a be box.
dcc
I use Febi Seals, no problems in last 8/9 years that I can think of
dobboy
I've used several sets from the Gearbox shop on ebay, all good.
