erbs
A Question About The Spark
erbs
on my 205 i was with miles (goodwood) today and we tested to see what kind of spark there is
on tickover we looked at the spark and seemed very weak, so we tried another coil and ignition amp and still the same
the tickover was erratic today, hunting really bad and then be some what ok tickover, i got a set of new leads ages ago, cheapies i think they were
could the cheap leads be holding back the spark, the cars ok when driving,just seemed a weak spark, i'm used to seeing a bright blue spark on engines rather than a pail weak one
It could be the leads or the dizzy cap and/or arm but also check the engine earth wire and the battery terminals.
toolie72
When I had bad spark plugs and leads the car was hopeless under load as I suppose would be obvious-so obvious I discounted it a nd blamed everything else!! Doh
Agree with above comment-if your earth has high resistance you will get a weaker spark-it's just a circuit after all
