David1982
New 205 Really High Idle?
David1982
Just picked up a 205 Gti 1.9 and all running fine. Timing is bang on but the idle is very high!!! Any ideas?
ATK
Air leaaaaaaaak
Edited by ATK
Capa
As said, start with an air leak, they can cause havoc. I think some people set the idle high to mask issues when you're buying - it happened to me. :(
Telf
Air leak- check the bolt that holds the filler neck on. Its attached to the inlet manifold. Mine was loose - car was idling at 2000rpm....
Other than that all the breather hoses - especially around the clips and at bends like on the one that comes off the top of the oil filler
good luck
