Juttie205
Earth Blocks
Juttie205
As title i have one under passengers side and one on left hand side of coloum and that one i had 2 connectors in but then realised that the single earth wire for stereo had to go there so this has left a earth multiplug with no home i think its for door loom should there be another earth block on drivers side and if so where?.
many thanks
Juttie205
just had another look its the earth multiplug for the drivers side door loom where does this plug into?.
mrfirepro
there should also be an earth block on the right hand side of the column....
Edited by mrfirepro
Juttie205
I have one on left hand side so will just fit another to right hand side.
Edited by Juttie205
Silky
Anyone got a photo of earth blocks on both or either side of column with wires plugged in?
Where do these wires then run?
Juttie205
1 will have the earth multiplug from drivers door loom other one has a multiplug from main loom and single connector for stereo earth i believe.
mrfirepro
just as a pointer for the earths around the steering column, there is a single yellow connector/wire which I connected onto the earth block, which in turn bought a (choke iirc) light on the cluster. Leave it disconnected. :)
Silky, are these any help
Edited by mrfirepro
Silky
Cheers fella. Will take a look and see what I've got missing. Thanks.
Juttie205
all mine sorted now so thanks fellas.
