Danez
Short Shifters?
Danez
I've been lookin at getting some new gear linkages. Specially these ones from pug1off with the short shifter:
http://www.peugeot-tuning-parts.co.uk/205-gti-be3-uprated-steel-gear-linkage-kit-309.html
Anyone had any experience with these? Any good?
Also with the short shifter is it worth it? Or is it personal preference? I've had a look and everyone who seems to have a short shifter installed to thier car much prefer the shorter throw and find it to be a better experience once used to it.
Whaddya reckon?
I don't have one, but I have replaced most of the bushes in the system with standard bushes (about £5 ) and some Pugracing linkages.
dobboy
No experience of the above and haven't got a quickshift, but have these fitted to mines which are all alloy, heavy duty but light (and won't rust).
http://bakerbm.com/205.php?data=gearrods205
or (and the bits to make your own linkages)
http://www.constella.co.uk/home/index.php/shop/gear-linkages-quickshifts/group-n-linkages
Pug1off's just look like a bit of galvy screwed rod with a bit of heatshrink melted over them from the pics.....
Danez
nice one, they look well. Is this for the be3 gearbox then? Or does the be1 and be3 share the same linkages?
dobboy
I'm not sure, I think they're the same but can't remember to be 100% sure.
Look in my Ebay shop, the Q/S is dead simple to DIY if you need one, All the rods I supply use Rolled threads and plated, as said the 1off looks like a bit of threaded bar which is weak and bends with ease.
AlexRS2782
I've had a set of Miles gear rods fitted on my car since late '09 and they are still going strong :) Fairly certain there's a short shifter kit on the car as well (unsure of who made it) but the two together with a new set of bushes in the right areas makes for a nice precise gear change.
Capa
I'm a bit intrigued by this - personally I find the steering wheel - gearstick distance in the 205 pretty much spot on, and quite enjoy the slightly porridgey gearshift.
Let us know how you get on with it.
Ozymandis
Quickshift
I do as in this link for a shorter lever throw. and fit two new pivot bushes.
i tried a set of all metal rods on my girlfriends car and she didn't like them as they rattle.
cheesegrater
I just extended the bottom ball on my shifter. Easy and free haha.
Edited by cheesegrater
Ozymandis
Thats unusual, my adjustable spanner has no balls on it.
My gear lever has one though.
cheesegrater
You must struggle undoing things then ;)
acox99
I bought a ball joint and extended the L shaped gear quadrant on the output/ gear box side. It's the longer arm facing forward. That way if I didn't like it as a shorter throw I still retained the original position. It seems to Work well.
I live in the right part of the world to understand this, I'll bet many others don't!!
7BC21692-3EE5-4ED7-B088-E891D9D26B55_zps
Mine.
