lando9000 2 Posted February 2, 2016 (edited) Hi, We've just installed a BE3 box and bits and pieces on an 89 1.6 gti. The car previously had a BE1 box and we've changed most of the bits and pieces for the BE3 conversion done but we're stuck on the gear linkage. We connected up the linkages as they were with the BE1 box but it doesn't seem they fit. When they're connected, we can only select what feels like third, fifth and reverse. Are there different linkages for the two boxes or is there an adjustment that can be made to any of the three rods? Any help appreciated. Edited February 2, 2016 by lando9000 1 Share this post Link to post Share on other sites
welshpug 1,676 Posted February 2, 2016 linkages are the same. sounds like someone has had the top arm off and not engaged it with the selector shaft properly. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted February 2, 2016 Have you installed the reverse cable? if so remove it Share this post Link to post Share on other sites
lando9000 2 Posted February 21, 2016 Have you installed the reverse cable? if so remove it Sorry for such a late reply, haven't installed the reverse cable yet. Share this post Link to post Share on other sites
lando9000 2 Posted February 21, 2016 linkages are the same. sounds like someone has had the top arm off and not engaged it with the selector shaft properly. That's exactly the answer I was looking for. This a 2nd hand box so I'm not totally Sure of its history but say someone had the top arm off hadn't engaged the selector shaft properly, how do you go about re engaging it. Share this post Link to post Share on other sites
welshpug 1,676 Posted February 21, 2016 remove the arm, drop the shaft down enough to rotate it a bit and locate it properly, lift it back up and refit the arm. 1 Share this post Link to post Share on other sites
lando9000 2 Posted February 21, 2016 remove the arm, drop the shaft down enough to rotate it a bit and locate it properly, lift it back up and refit the arm. Great. I'll try that during week at some stage. Thanks for getting back so quick. Share this post Link to post Share on other sites
