David1982
Lead Coming From Dizzy To A Plug Broken... Help
David1982
Hi all need to buy the plug that come from the dizzy any ideas. Don't no what it's called to search for one
Simes
I don't think you can get them.
Have you tried looking on service box?
steve@cornwall
Can be re soldered. Cut the plug back if necessary to gain enough to solder to. Can be re-insulated with punto or silicone. At worst a "get you going" solution until something better turns up
David1982
What are they called so I can look for one? Excuse my lack of knowledge
jord294
Signal lead iirc
5911.34 NLA from maindealer
I have a BNIB 5911.32, which is more commonly used on 1.6s
David1982
Would that work in mine. Dies the main dealer still do them?
jord294
Would need your dizzy number to confirm if it fits, but if yours is a 1.9, I doubt it will.
NLA from main dealers for some time sadly.
Only a couple of people I know may have new ones, but don't know if they'd be prepared to sell
David1982
Jord it's the not the fly lead it's the black plug that the yellow one plugs into. Signal lead.. It's frayed and the pins the the black plug are lose
3 pin jpt male jpt plug, junior power times, or power timer plug.
look up vehicle wiring products, polevolt, simtekuk, rs, ebay.
