Juttie205
Fuel Pipes In Wheel Arch
Juttie205
As title has anyone got a picture of the piping including the breather vent as i think ive worked it out but just want to check.
mrfirepro
Hi Justin,
Here's a few, there was also a thread about this not long ago, maybe worth a search.
Farmer gave me the P clip (for free :) ) and I think he had a few left
Hope these help
Juttie205
Thanks paul thats great but even more confused now as thats not how mine was when i removed as i didnt have that white pipe with quick release fitting do you know what size it is as maybe can just use some normal pipe. also my vent was not at top of filler neck so will have to have another look.
Juttie205
Paul on the 2nd picture the white plastic pipes where are they going to as I know one end connects to top of tank and runs up behind the the filler pipes up to neck do these go into valve in filler neck?.
Juttie205
Mine im sure must run a slightly different system as my valve was located near my rear valance and I'm sure I had a rubber hose that ran from tank round wheelarch to vent anyone else got this setup.
mrfirepro
It was mentioned in another thread that there seems to be a few variations.
On mine the clear pipe (from the tank) ran behind the filler pipes, upto the one way valve and then out through the rear of the wheel arch. The one way valve did seem to have some sort of fixing arrangement on it but I never figured it out.
Edited by mrfirepro
Juttie205
anyone got a picture of other set up please.
