erbs
Badges
erbs
i got my badges back from the bodyshop and the pins are broke, would it be better to get the replacements from baker's?
unless i can get phase 1 badges which i think is unlikely so the pins that you you can get seems to be the only option
Are they strong enough and won't fall off??
pugdamo
I got a set of those repair pins, I thought they were brilliant, I cleaned the area up the JB welded the new pins on, they are going to be a lot stronger than the original plastic ones. I bought the plastic cups aswell but I found these to be a little slack in my 1/4 panel so reused my original ones.
farmer
Go with Baker repair set
Warning though he's not back till the end of January for orders.
Museum sell new badges as well as me.
erbs
Thanks guys i think maybe the cheaper option would be to go for the reapir pins
what do you use to glue the pins to the badges?
erbs
thanks for the advice on the glue, just out interest, how much would they all cost for both rear quarter badges??
dobboy
I've got a set of the baker pins to fit, but have my badges on just now with 3M panel foam tape.
Pugdamo, where you get the bullets/ grommets? I've lost mine. Am i better getting a set off a 205 i know of in a scrappy?
pugdamo
I got mine from BBM. When I bought the repair pins there was an option to get all the fixings aswell. As said they were a little slack in my 1/4 panel though so i ended up using my original ones.
