Danez 6 1 Cars Posted December 23, 2015 Hello chaps, My heater fan does not work at all. It used to then when I turned it on it took a while to get going and now it does nowt. I'm looking to removing it and giving it a good refurb by using that handy guide in the articles section. Only problem is removing it. The Haynes manual says I need to drain the coolant out which is something I'd like to avoid. So is it necessary to drain the coolant to simply remove the fan?! Thank you for your time -Dan Share this post Link to post Share on other sites
pugdamo 111 2 Cars Posted December 23, 2015 No need to drain the coolant, it's located underneath the glovebox, if you remove the soundproofing then you will see the 3 screws holding it in. Very easy job to remove. Share this post Link to post Share on other sites
Danez 6 1 Cars Posted December 23, 2015 No need to drain the coolant, it's located underneath the glovebox, if you remove the soundproofing then you will see the 3 screws holding it in. Very easy job to remove. Nice one man just what I want to hear! I thought it was strange that I had to drain coolant. Must have been on about remove the matrix not the fan itself, cheers. Share this post Link to post Share on other sites
Danez 6 1 Cars Posted December 23, 2015 Okay so the motor is fine as I tested it on a battery. So my next best guess is the control of the fan not working? I want to make sure it's the control knob that's faulty so how would I bypass the control knob? I have the panel all out and the circuit board for the three knobs is showing but I'm not sure what each track does. Thanks 1 Share this post Link to post Share on other sites
Anthony 1,003 Posted December 23, 2015 It'll likely be the resistor module which is next to the fan Share this post Link to post Share on other sites
Danez 6 1 Cars Posted December 25, 2015 It'll likely be the resistor module which is next to the fanYeah i took that out and there was loads of s*ite in it so have it a good clean and it works every now and again it's very temperamental. The resistor is proper rusty like.Merry Christmas btw! Share this post Link to post Share on other sites
