Lukespeed
Oil In A Distributor?
Lukespeed
Evening all,
I took my distributor off tonight to check the id on my cam, and noticed when I picked it back up off the work bench that where the vacuum screws to the distributor housing was leaking quite abit of oil out of it..
I'm gonna take a wild stab in the dark hear and assume that there shouldn't be any oil inside my dizzy?
Any ideas what could cause this? And the best/most cost efficient way of rectifying this?
Cheers in advance!
iPlod999
Could be a failed distributor O ring oil seal.
Have a look at eBay item number 311499015323.
It could be a very good £2.70 well spent.
Lukespeed
Cheers il get that ordered!
Is it worth opening it up and cleaning it out with brake cleaner? Or am I best off leaving it be?
hoodygoodwood
I believe there is an internal oil seal on the shaft that runs through the dizzy , with age it lets the oil through . Most of the dizzys I have opened up are wet with oil inside , I had one rebuilt by H+H a while ago and the shaft is stiffer to turn so I assume they replace this seal and it is now doing its job .
Not sure how much the oil will affect the operation of the distributor .
The external 'O' ring is often in pieces and will certainly cause oil to leak down onto the gearbox , as said they are cheap and fairly easy to change .
mhyphenl
I had this on a 205 GTX, the oil was managing to drip into the clutch from one of the screws in the side of the dizzy. The clutch was slipping so I had it replaced only for the new one to start slipping after a week or so, that's when we niticed the oil on the underside of the dizzy. It was the internal oil seals which meant a new dizzy, if the o ring seal goes it just seeps down the side.
