Juttie205
Ecu Under Dash
Juttie205
has anyone got pictures of how it mounts as cannot seem to work it out been a while since i took it out.
mowflow
It mounts to a black bracket which you need to fit along with the dash. The bracket is held in place by the large stud on the dash that goes through the bulk head to the windscreen drainage area.
My lower dash is still out so I should be able to get a photo.
mowflow
Sorry for the delay. Got the pics but having some tech issues
Edited by mowflow
mowflow
Hopefully of some use. You can't see the bracket but at least you can see the position and how the ecu fixes to the bracket
mrfirepro
may help as you can see the bracket and hole
