Russell_ds80
Weber 45 Throttle Cable To Pedal, How?
Russell_ds80
hi. im in the process of fitting twin 45s to my mi16 205. im struggling to work out a way of fitting the cables to the pedal. i have one of the alloy block things that bolts to the pedal but unsure how to hold the cables.
any help with pictures would be brilliant. cheers
Daz_C
I just used/use a standard pug cable. not had any issues with that set up in over 15yrs.
boldy205
The two outer cables need cable stops fitted to the bulkhead, (should be available from Webcon etc). Then feed the inner cables through to the alloy block that mounts to the top of throttle pedal, using the grub screws. Hope that makes sense?
