blandy 29 Posted December 3, 2015 Has anyone got one of these fitted to a 205 gti6? If so what are they like to install? Share this post Link to post Share on other sites
petert 580 Posted December 3, 2015 Parry has one. If you're not into wiring you might find the installation technically difficult, but otherwise straight forward. Make sure you remote mount the oil pressure sensor. Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted December 3, 2015 Race technology are pretty good and reasonably straight forward to install although the instructions can be quite confusing. They do however have very good technical support if you need it. I'd use their sensors and just calibrate the 205 fuel sensor which is pretty straight forward, just have to input changes in voltage as you fill the tank up 5l at a time. There are quite a few options on the display which can all be changed depending on your preference. The actual display is well laid out and easy to change through the different modes. Share this post Link to post Share on other sites
