blandy
Race Technology Dash 2
blandy
Has anyone got one of these fitted to a 205 gti6?
If so what are they like to install?
Parry has one. If you're not into wiring you might find the installation technically difficult, but otherwise straight forward. Make sure you remote mount the oil pressure sensor.
j_turnell
Race technology are pretty good and reasonably straight forward to install although the instructions can be quite confusing. They do however have very good technical support if you need it. I'd use their sensors and just calibrate the 205 fuel sensor which is pretty straight forward, just have to input changes in voltage as you fill the tank up 5l at a time. There are quite a few options on the display which can all be changed depending on your preference. The actual display is well laid out and easy to change through the different modes.
