omri617
1.9 8V Primes Only After 3 Attempts
omri617
Hello there
Recently I need to turn the ignition on / off 3 times at least to hear the pump primes.
I replaced the fuel pump relay but no change..The fuel pump is new also.
What could be the problem?
Thanks a lot.
If this is Jetronic then that sounds fairly normal - they don't generally prime every time you switch on the ignition (indeed often they don't prime at all)
omri617
Anthony you opened the Pandora Box ;)
It's a DKZ engine runs with 1.6 ecu(340), 1.6 afm and dizzy unfortunately
If I don't do the 3 attempts thing , the car takes much much longer time to start..
Edited by omri617
If its taking ages to start without priming, I suspect that you've another issue, such as something on the fuel system (pump, FPR etc) not holding pressure as it should.
Even without priming, 205s should normally start within a second or so of turning the key.
Telf
faulty ignition barrel or a faulty tacho relay ?
