flyfisher
Will These Fit
flyfisher
Hope I'm in the right section. Thinking of fitting a set of second hand lenso alloys to my cti no sure if they will fit. They are 15 inch X 6j. 35et. The problem may be the et as car has a 309 Gti rear beam 15 inch 1.9 speed lines fit fine but it's the et that I'm not sure of. Any one no the et of 1.9 speed lines. Any help would be helpful many thanks peter
Nope, the offset is well out and they'll foul on the rear beam trailing arms and proabably the front struts too.
For a 15 x 6" wheel you'll want something around ET15-20 offset (standard 1.9 wheel is ET19)
20 mm spacer should do the trick though.
flyfisher
Thanks guys looks like I'm refurbish the speed lines then.
