P I Staker
Xs Mid Corner Miss Fire
P I Staker
My XS seems to suffer heavily from fuel starvation when cornering quickly. I'm not talking flat out either just if you're making decent progress.
It happens with a full tank of fuel so I don't think it's an in tank problem.
Is this something that can happen with these carburettors?
calvinhorse
Floats in the carb are sticking or burst
P I Staker
I don't know much about carbs but I suspected something like this.
Cheers!
Edited by P I Staker
pugdamo
I had exactly the same with my old xs and as said it was a split in the float, not very difficult to replace either, I think the problem might be trying to find a replacement now though.
N3VRAM
Solex are crap in my opinion, had 2 with this issue one would die when the engine got hot. Swapped to a weber and never looked back!
boldy205
common problem, could just be the float level needs re setting. Haynes manual covers it im sure.
Adrian co
I solved this probley buy usin a bigger inline fuel filter wel that worked for me anyway
dawning
@N3VRAM Which weber carb do you use?
boldy205
Not sure what he uses, but the DGAS was a popular mod a few years ago. Nothing wrong with a correctly working solex though.
dawning
Cheers, been trying to find out a bit more info. My solex works ok never touched it though, was planning to rebuild it at some point but if a DGAS bolts on and makes the car more powerfull its an idea.
boldy205
Stick a set of side draughts on if you want proper carbs!,
tdr_1976
This is what I've done to mine :)
11701084_10153104388797861_8653335453953​
boldy205
​Thats lovely!!
dawning
tdr, what carb is that?
looks soo clean!
