Juttie205
Flywheel Help
Juttie205
I have tried 2 be1 clutches and they do not seem to line up with the dowels on the flywhell are there different flywheels??.
check the friction surface diameter on thw flywheel and actual friction disc.
which engine is it? there are two common sizes for an xu with a be box, 200 and 215mm, the latter found on anything 16v 1.9 and 2.0, the former is found on the 8v xu engines 1.9 and under.
Juttie205
right friction disc is 200mm but on flywheel its 215mm so guess for some reason ive got wrong flywheel so has anyone got one?
Paul_13
Has it got the timing teeth on it?
Juttie205
yep i think its the wrong flywheel
Paul_13
Nothing wrong with that.
Get a 1.9 MI 16v clutch. The 1.9 mi16 4x4 clutch fits as well
Bigger flywheel /clutch is better in my opinion. Keep the flywheel!
Paul_13
You already have flywheel and bolts holding it on
Juttie205
would the bigger clutch work on a be1?
yes, just fine.
early mi's had be1 boxes, differences to be3 are minimal and certainly none at all relating to pressure plates or friction discs.
had an mi16 clutch and flywheel on my 8v for 8 years.
Paul_13
I believe so, that's one for welshpug to confirm
Edit:
Already answered :lol:
Edited by Paul_13
that looks like an 8v flywheel, theres no timing teeth, if it really is 215mm then its a diesel flywheel :lol:
I would check the numbers on the pressure plate, also whats on the box it came in.
Edited by welshpug
Juttie205
It definitely measured 215mm on flywheel and the 2 clutches ive tried are both 200mm and the pressure plates are same but do not fit. God know why its had a diesel one fitted then.
