samthornton1990
Xu To Jp4
samthornton1990
I've just bought a 1.9 gti but I think the engines on it's way out, very tappy and the bottom end has some lovely noises coming from it.
I'm between rebuilding it or putting a 1.6 16v in as my mate used to have one on his 106 which used to leave my old 205 standing.
I've had a search and nothings come up. Had anyone done this conversion in a GTI?
If so what is required to to make the engine fit as the mounts are different etc
Any help would be appreciated ☺
a healthy 1.9 will keep up just fine and have a gearbox that wont s*it itself, unless you want to go into doing a BE4 conversion too, I'd get another XU.
plenty of topics on fitting the TU engine in, the brackets on the shell are all the same for a later TU.
samthornton1990
Are the MA boxes that bad? I will look into rebuilding mine then, just after my last one I figured the TU would be the better engine.
I was gutted, finally got my dream car which on paper is quicker than the 1.6 16v and next thing he went steaming past me. I was pretty gutted!
if it was lighter the TU5 would make sense, its a heavy old lump for its capacity though, the 1.9 makes more sense.
and yeah the MA is a bit of a chocolate teapot.
my personal experience is that a decent 1.9 will have no trouble at all keeping up with a 106 gti, they're lighter and have more power after all...
samthornton1990
I'll get looking for a healthier engine then when I recrue some funds/ fine one to rebuild on the side!
The MA gearbox is OK it just doesn't like abuse or much over 100k before needing new bearings, mainly the input shaft one nearest the clutch, but it's a backwards step personally, Better off with a 16v XU
samthornton1990
After doing some reading I think I may stick with the XU, found one on ebay for cheap!
