td_w
Someone To Fit Seats And Belts
td_w
Hey there
Sorry if this is in wrong section, please do move if it is, I couldn't find a better spot.
I have some great new seats and harnesses (well not new, new but new to me) and I need to get them fitted as I am not good enough to do it myself. Does anyone have any recommendations in South Wales/Bristol or even London area of someone who can do this properly?
sp_en_ny
When I bought my CTI the rear seats had lap belts only. I took the car to a company called Quickfit safety belt specialists to convert the lap belts into a 3.1 belt. They have been in the game for donkeys years, were the cheapest I could find and the service was excellent. They had several other classic cars they were working on at the time. I could not fault them and would defo use again. Web address is www.quickfitsbs.com and are based in London. Although not sure if they would be of any use regarding the fitting of your seat.
dcc
Bucket seats?
td_w
Thanks guys, they are Sparco Corsa seats, side mounting.... and I have some old Cobra's that are base mounting but adjustable..... its not even that hard to do, may end up doing it, but the belts worry me slightly!
belts are easy, they go to the harness bar on the cage.
seats easy for a fabricator/welder.
td_w
Cheers welshpug
The cage only has one cross bar on the back and its diagonal so don't think that will work?
Would they be able to weld frame to runners to keep that function? The current Cobra seats are bottom mounted to runners.....
td_w
Cheers welshpug
Matt Holley
What all of them?
Matt Holley
I had these welded in. you could get some universal seat runners from Merlins, mount them to the welded in rails and bolt the side mounts to that if you wanted although I just bolt the side mounts to the rails.
Look for someone that does race car prep and they should be able to do it, I had my omp cage widened and a X bar added with harness bars but its all down to how much you have to spend. If I did it again I'd just buy a decent cage in the first place.
stufarri
I like the sound of this for my CTI.
Any pictures of the work they completed and detail on price please?
sp_en_ny
From memory they originally quoted about £350, when I had it done it came to just under £300 as they completed the work quicker then what they had originally provisioned for so this was a nice added bonus. The work includes new seatbelts and you have a choice of about 20 colours as well.
If you PM me your e-mail address I will take some pics and e-mail them to you. they are static belts and so do not wind away like the fronts. I have one each side and they put a lap belt in the middle for me, you can also have the middle one done but it means restricting your boot space as the belt has to run at a certain angle, could not get mine done as it has 2 12inch subs in there.
Pretty sure you can do it yourself as long as you know where the mounting points are and what angle is required for the belt and of course the corrects bolts etc.
Edited by sp_en_ny
