amusingadam
Head Gasket Fitting Issue
amusingadam
Left my mate to fit my head gasket last night while I had to shoot off. When I got back head was on all torqued up, on the down side the part if the gasket that sticks out the side of the head was on the cambelt side the wrong side. Obviously he was trying to help. My question is have I now got to replace the bolts and gaskets again or by some miracle can I reuse them . Payen gasket elring bolts. Cheer thanks for you patience
Personally if it hasn't run I'd re use the gasket but probably not the bolts.
see I'd be the other way round, bolts fine but not gasket.
j_turnell
I would get new bolts as they should be stretch bolts, if it's not been run, prob get away with re-using the HG.
Sorry, the bolts are toast.
dobboy
After doing my first HG two days ago i'd be inclined to agree with WP.
Reason being, with the 16v pug say the bolts have to be a maximum of 112mm long, which to me implies if they are used and are less than 112mm you could re-use them.
However, after doing mine, torq'in to 70nM and the additional 160 degrees, i wouldn't risk reusing bolts as the oomph required to do them made me feel a bolt could snap at any minute....... (I snapped a good 3/8 bar doing mine)
Would also think once a gasket has been compressed, it will always have been compressed..... And might not fill and tiny machined valleys etc
which engine is it btw? alloy are stretch but iron aren't.
ALEX
I Thought the Torx type could be re-used but the Hex type can't. (Stated in the Haynes IIRC)
Us Northern folk are often forced to repair on a budget. If the bolts tighten up without popping out of the threads then they should be OK. Only seen the once on an XR2 with reused bolts.
If the engine hasn't run and the bolts haven't been hot, then I'd chance re-use them..... But that's me.
Worse case scenario is you have to do the head gasket again.
amusingadam
Just a 1.9 xu9ja
amusingadam
So here's what I went for, new gasket old bolts based on the fact I couldn't get the bolt in time, as I need the car for Sunday so watch this space.
dobboy
Fingers crossed for you.
ALEX
Probably what I've had done,
Just check the bolts are still tight after a few week of driving.
amusingadam
As it's main use is for track it gets check over after every blast I will add the bolts to my check list
you wont need to do that if they were tightened correctly, there's no test you can do really!
amusingadam
I used the same settings as I used last year DamirGTI posted them.
ALEX
Wasn't my point.
Duroc
Other way round. The Torx are stretch ones.
ALEX
You sure?
I am. Torx head are stretch type.
dcc
Not that the man with a cap needs any reassurance, but yes, torx head are stretch!
That's news to me. Why else would you turn them an additional 160 deg.?
RossD
Maybe another thing to consider - If your mate got the head gasket the wrong way around, has he maybe also forgotten to put the spacer on the bolt above the water pump, meaning its now also going to leak like a sieve? Certainly worth checking.
amusingadam
I have taken it all apart myself now and redone it just done my final torque checks all good so back on the track tomorrow.
