Boiled Brake Fluid (Golf Gti)
I managed to overheat the fluid in my Golf, due to a sticky rear caliper. The fluid was bubbling out the top of the cap, pedal to the floor = no brakes :blink: . New pads, discs and a thorough cleaning of the calipers will be done, but I'm guessing I should get the fluid changed as well, as that will have air in now?
if theres enough moisture in the fluid for it to actually boil then its well overdue changing yes, there will be a lot of air in there now.
Should be changed every two years at least.
aldworth33
As wp said it needs to be changed often as brake fluid absorbs water readily so once it's been in a while the boiling point lowers
Golf
Nope sorry don't understand?!?
Thanks all. As I thought then, though it was changed (by a main stealer) less than 2 years ago. There can't have been that much moisture in the fluid, but I guess the over-heating due to the sticky caliper has exacerbated things?
Richie-Van-GTi
I think its a scottish game involving silly trousers and a wonky stick to chase a small dimpled ball round a massive field........wierd!!
