timoth123
Door Cubby Hole/ Storage Thing Issue
timoth123
So the storage hole thing that holds the elc window switches won't stay attached to the door at multiple points. The self tap screws just pull out due to the holes being too big and not giving enough grip. I can't get bigger screws due to their heads not fitting into the plastic channel made for them.
Anyone any ideas on securely fixing? I was thinking of ising some sort of wall plug or plastic insert.
3E3F8A3D-D534-4368-9746-1FD4AF3F8666_zps
Edited by timoth123
lightflow
Yes - use rivnuts. These will make it ultra secure. Well as secure as you can get with 80's french plastic and 1mm sheet steel.
I used M5 rivnuts and they are brilliant. You then just need some panhead M5 machine screws.
You will need a ruvnut tool -there are some good and relatively cheap ones available. Will look up later for you..
Edited by lightflow
timoth123
Rivnuts! Of course!!!!
Why didn't I think of that! Good plan!!!!!!!
Thanks very much!
ATK
Or wrap tape round the screws, worked for me!
farmer
I have this also, good idea Ashley, going to do that as well
Dizzee stuff
Plenty of plastic inserts on ebay, not sure I would use rivnuts bit of a over kill. With water going down the door corrosion could also be a problem
