105e
Engine / Gearbox Weight Mi16 1.9,
105e
Anyone know the weight of the complete assy, or even the 8 v as it must be close, thank you.
dcc
Xu7 16v is 88kg without flywheel (basically same as mi16 alloy block) with head
Xu9 8v is 70kg
Gearbox is 35kg
Xu7 flywheel is 6.5kg
Mi clutch is 5kg
Slim starter is 2.5kg
Xu10j4rs block and head is 114kg
Gti6 exhaust is 7kg
Loom is 3kg
Bbm mounts 2.5kg
Mi16 piston and rod is 1kg
Gti6 alternator is 6kg
Ttv flywheel is 3.7kg
dcc
Its about 17kg differnce between the mi and the 8v like for like.
