tommy gun
An Fittings
tommy gun
Does anyone no if there is a an fitting that pushes on to the end of the standard fuel rail.
Had a search but can't find quite what I'm looking for.
I'm wanting to swap all the fuel lines to ptfe braided but I've been told it can only be used with an fittings.
whilst not ideal, you can fit a teflon hose over the barbed fitting, so you should be ok on the return from the FPR to the metal pipes, you can get a hose finisher with a clip in it to stop the braid being exposed.
for all the other joints which are under the full pressure from the pump it is better indeed to use the proper barb and olive type AN fittings, with the original 205 fuel filter this will be quite straighforward.
have a chat with Alex at
missed the link there somehow, look up torques.co.uk
HERMAN
I Silver Soldered a pair on AN blanks drilled out to the size of the fuel rail on my gti6 rail.
Have a look on my build thread.
If your struggling I could do it for you.
