mhyphenl
Piston Ring End Gap
mhyphenl
Just re building the engine and got round to piston rings. Haynes says end gap of 0.3 to 0.5 mm, I have 0.8mm! How critical is this? Do I just need new rings? What is involved in re honing, do I need just different rings or new Pistons and liners???
Sorry for the quick fire questions but I've stopped building until I'm sure what to do!
Are these used rings and liners?
Stu
Where are you measuring the gap? At the top of the bore or half way down by any chance?
mhyphenl
Yes, used Pistons liners and rings. Measured about an inch down so on the worn part of the liner!
Stu
Used rings you say? Are you not replacing them as part of the build?
It only takes a small change in bore wear to make a large change in ring gap, because perimeter = pi x D. Thus 0.1mm of bore wear will equate to 0.3mm increase in ring gap. What was probably 0.5 has become 0.8.
mhyphenl
Hi, yes I get you. I guess my point is, bearing in mind there are probably other areas of the engine that are sub optimal, is an end gap of 0.8mm a significant problem in both running quality and performance? If it is then what's the protocol, just new rings or is it the liners that have worn? In which case are they honed and oversize rings or is it new liners pistons and rings?
The liners will be worn. If you install new, "pre-gapped" rings, your end gap won't improve. Ideally you need to hone the liners and fit new ungapped rings. However, the excessive gap itself is not the problem. As the bore size increases, the tangential force of the ring on the bore decreases, allowing blow-by. Any new rings will seal better than old rings for this reason.
mhyphenl
Ok, I take it that in gapped rings need to be fitted professionally? I understand what you mean in that the nearer the rings get to their natural unfitted shape the less force they exert on the liner but is .1 of mm in diameter going to have a significant difference? I'm not really trying to be tight but on the other hand it's going to be a £150 job ish!
Pre-gapped rings are for muppets, with little to no fitting experience. Ungapped rings are for professional use, where the installer will increase the ring gap using special tools, for the desired application. If money is tight, throw the old rings in and hope for the best!
For the cost of new liners I go that route all the time as finding a std liner that is out of tolerance and cannot be honed makes it allot more in the long run
mhyphenl
So miles, you suggest new liners and rings!? What kind of money are we talking for that?
Around £175.00 for liners, £105 for rings
