davey205
Intermittent Ohhhh Like Sound
davey205
Got a intermittent "ohhhh like sound", it will ohh for a bit then quiet then ohhhh..... a bit whiny / creaky but certainly not wheel bearing type drone its mainly provocable just after your hard on the power you can feel it slightly through the steering as a slight vibration as if something isn't spinning quite as freely as it should be.
Iv'e had a feel and one of the cv gaitors has oil on it looks to be old oil everywhere....
I think I can mange to change a cv gaitor but how will I know if the driveshaft is knackered as well? I think its a bit over my head to change that so would probably just take it to garage.
Unfortunately it does not do camp Kenneth Williams impressions and continue with an "Ohhh Matron" but maybe this will develop?
Edited by davey205
boldy205
Nothing wrong with drugs!
boldy205
Joint will feel loose and 'limp' if worn, which may explain the vague campness!
Simes
Bearing on long driveshaft?
Slo
coincidentally my gearbox/nearside driveshaft is making an ohhhhhh noise too after approx 30 mins of driving scared the hell out of me when i went to wales in it 400 mile round trip but it made it there and back with the ohhhhhhhhh
davey205
Not quite sure what you're implying there.
anyway it turned out the grease had gone hard in the driveshaft and just needed repacking... haven't had the problem since.
Edited by davey205
boldy205
sorry just a bit cidered up and found the way you worded your post quite entertaining With the Kennith Williams bit! ☺no offence!
