Weser
Quadrant Lever Question
Weser
Hi all. Replacing my bushes and got the L lever off and bushes out. There is a a spacer through the lever which the bushes are pressed into. Now I'm hissing that's not supposed to rotate? Mine rotates about 10deg. Is the best thing to put a little weld on it or press it back together in a vice?
cheesegrater
My understanding is that the bronze bushes are pressed in and shouldn't move. The sleeve is not pressed in and acts as the point of movement when the bolt clamps the whole lot down.
Edited by cheesegrater
allanallen
I welded mine to stop it moving ;)
Weser
Ahh good I welded mine as well. Was sure it wasn't supposed to move. Gears feel a lot better.
