amusingadam
Best Oil For 205
amusingadam
simple question which is best to use in a 205 gti to use on track days currently its running 5/40 fs (fuchs titan pro).
Thanks guys
never had issue with bog standard quality 10w40 in all my engines, its what peugeot spec for most of them, if its getting too hot add a larger oil cooler.
amusingadam
Got a 13 row one just want to make sure it's fully protected when throwing it around hard
Edited by amusingadam
idoari
i use the best oil that i can - Castrol MAGNATEC 10w-40
this oil is very special because it not only lube the parts but chemically bond to the metal even if the engine is off.
it is more expensive but i think it's worth it in the long run.
