Phil205
Exhaust Manifold
Phil205
Hi,
My exhaust manifold has a hairline crack and is making noise.
Does anyone know where I can source a replacement ?
8v I'm assuming by your signature? Fairly common issue if so, but there's still plenty of good used items out there.
Best bet is probably to start a topic in the "Wanted" forum as someone on here is bound to have an uncracked one surplus.
Phil205
Are the nuts normally hard to get off ?
I have been quoted 80 GBP for labour to fit a replacement if all goes well, but 400 GBP if they have problems getting it off.
Is it possible :-
i) to buy a new replacement ?
ii) to weld the current one ?
Edited by Phil205
hoodygoodwood
If you still have the original steel nuts that take a 10mm socket they can round off very easily , the moment it starts to round , stop and hammer on a smaller imperial socket which should allow you to remove the nut .The worse case scenario is that the stud breaks , I have only had this once and it was a nightmare to drill out with a right angle drill . When done replace all studs and nuts with the newer 13mm nuts that are copper coloured .
The original gaskets can rust away and the manifold can corrode away around the port which could be causing your blowing .
As these become rare welding might become a necessity but most cast iron manifolds are warped as well so might need more work .
You can use 306 manifolds etc to name a few as they all used the 8v XU head, Yes the 2 nuts that can give issues are the 2 which you cannot get a socket on, 2 middle lower ones which if in the car can be a right pain in the ****
farmer
Looks like you can still order at Peugeot
Phil205
Anyone know part number and price from Peugeot ?
Is it supplied with a new gasket ?
hoodygoodwood
I suspect a new manifold will be extremely expensive new from Peugeot .Around £20 to £50 on Ebay .
The gaskets are 4 separate individual items , they are not symmetrical so take care when fitting as its easy to get them 180 degrees out and partially block the gas flow . The diameter of the central hole varies a lot between OE and pattern parts , Peugeot gaskets 0349.70 are excellent quality and have the largest hole of the 4 different gaskets I measured .
Alan77
031494 Exhaust Manifold is £237.91
034790 Exhaust Manifold Gasket is £3.37 each (need 4)
While you're at it, get a new Peugeot exhaust fixing kit to connect manifold to downpipe. P/N 179845, £22.84.
The price of a manifold hasn't moved much (yet) since I bought a new one from Pug, maybe ten years ago.
Edited by Alan77
Phil205
Thanks Alan,
I checked with Peugeot.
034194 Exhaust Manifold is £237.91
034970 Exhaust Manifold Gasket is £3.37 each (need 4)
Sounds like the best route might be new gaskets and try a second hand manifold in the first instance.
