flyfisher
205 Mi16 1.9 Power Steering Pump. Problem
flyfisher
Please excuse me if in wrong section my cti has a mi16 1.9 from a citreon bx gti the power steering pump when engine is cold screams it becomes less as engine warms up also on both full lock I purchased a 205 gti pump but it appears different looks the same bar pulley wheel that's about double the size it should be. Would it be a bearing going in pump belt is on max adjustment and don't think its air in system it doesn't appear that you can put the pump pulley that's on my car on the new pump. And can't seem to find what pump me car is running. Has any one else come across this problem. Am I right in thinking pulley wheel is not inter changeable between pumps looking at it it seems large pulley is fixed to cam on my car and a smaller pulley to steering pump. Not like say a1.9 /I.6 gti any idears
dcc
your post is really confusing.
i assume this pas pump in on top of the gearbox and driven off of the cam?
try a new belt
flyfisher
Can't seem to get a new belt size seems to be a problem. Yes your right it is on top of g/box tried 2 parts factor they can't find a supplier that can supply that size of belt
dcc
£4.13
Go to car parts 4 less
use bx 16v reg plate I found on google - J157LKE
Supplier Part Number AVX10X625 Type V Belt Fitted Quantity 1 Date To 06/1988 Other Information Driven unit- hydraulic pump
202440015 is pn for euro carparts and cp4l.
not 100% certain its right for you, but for £4.13 you won't go far wrong
I'm not sure that's right Dan.
BX will have a high-pressure hydraulic pump whereas 405's will have a PAS pump, and presumably the belts are different. A 205 installation will use the 405 setup.
Servicebox lists the belt as 530mm long for an XU9J4 405 Mi16 and it's not listed as NFP - part number 456912. It's the same belt that drives the vacuum pump on a 205/309/405 XUD7 diesel - a common car still on the road - so I'd be surprised if it's genuinely not available from a motorfactor.
flyfisher
Thanks guys have one on order thanks for your help
And I;ve always found the standard torque setting for these is not enough, Go at least twice as tight
