sport1901966
Brake Hose Lengths With Gti6 Calipers - Searched With No Success
sport1901966
Hi All,
I know this is a hugely covered subject and I really thought I'd find the answer I needed but seemingly have failed!
I'm looking at ordering some stainless braided hoses but want to get the fronts longer than the std 1.9 GTi spec (440mm Tip to Tip I believe).
Does anyone know what length is required to fit GTi 6 calipers with some certainty/experience, e.g. would 500mm tip to tip be ok, or would longer be required?
Thanks in advance,
Geoff
sport1901966
Thanks very much! Reasonable cost as well, only shame is they don't seem to be sell a set with these and rear hoses. Any idea on their length?
Kane
I'm sure if you contact Miles on here, pugracing is his site, he'd be able to sort you out.
jamie_1992
hopefully he has re stocked as he had run out when i needed some for my brembo's i had to put the callipers on the car then use a length of mig wire to trace where the line would run and then measure the wire. hope this helps
sport1901966
Thanks for the tip, speaking to Miles now but looks like he should be abke to sort out what I need!
