N3VRAM
Vts Rack Issue: Uk Rallye.
N3VRAM
Hi All,
I was wondering if anyone could point me in the right direction. I'm trying to put a VTS rack (2.6 turns) onto our our UK rallye. The new rack has the same square drive as the old one however it sits higher - see below:
IMG_0215_zpscw6ctcoi.jpg​
I was of the opinion after doing some research that these racks should be a straight swap if your current rack used a square drive. Am i missing something here as it seems that there's going to be a requirement for some alterations to the column before this will fit?
Thanks in advance for any comments.
Matt.
Loosen the bolt on the upper U/J inside the cabin and the lower column will slide up a bit. You can also loosen the four bolts holding the upper column to the bodyshell and there might be bit of movement on that too.
N3VRAM
Thankyou very much! I'll give that a go.
