JR20516V
How To Identify A Vts Rack?
JR20516V
Last year i purchased a VTS rack and now that is on the car i have found that it has 3.1/4 turns lock to lock when it should have a 2.6.
Interestingly i put up a stock standard 306 rack and it was exactly the same fit and fitted the 205 perfectly....it also had 3.25 turns lock to lock.
So i am in the midst of finding the hi and lo hoses for a VTS rack [difficult !! ] when i may be searching for the incorrect rack if you follow me..... i could have a standard Xsara rack sold to me thus chasing incorrect parts. I guess the VTS and VTR have completely different hoses?
The question is.....how can i tell if the rack is the real VTS one just by looking at it ??? [note: there are no hoses on it ]
‹How does it differ in looks from a standard Xsara or 306 as i think i may have been sold a pup :{
All the casings are the same externally as far as I know. Only way to check is put a spanner on the pinion wind it lock to lock and count how many turns.
JR20516V
Thanks Tom for the reply.....yes, i did that and got 3.25 turns lock to lock. It has" push on" hose connections which correct me if i am wrong the VTS was the only one that had this....the VTR was screw in.
The seller [a Pug mechanic by trade ] swears that this rack came off a VTS. Confused !!
it may well have been a vts, which in many countries was purely a trim spec badging unlike the UK cars, it may not even have been the J4RS engine in it.
S@m
The whole ph2 range had the push in hose fittings with the single bolt, including the VTR.
As said though, in many countries VTS was just a trim code, you often see irish 1.8 VTS badged cars whereas all UK VTS's had the J4R engine.
