jaggers12
Sorry Another Gti6 Wiring Question
jaggers12
hi guys sorry for another gti6 wiring question
ive connected all the wires in the pinned guide but the pin 14 on the double relay will not switch to a positive
also my 306 loom has 3 thick white wires my starter an fuel pump are defiantly correct but I don't know what the 3rd white wire is for
thanks
jaggers
jaggers12
No not yet ive been having to go to work instead gonna try and figure it out on Saturday
dobboy
Let me know if u can't easily suss it out.
dobboy
btw iirc, there was a thick wire associated with the airbag which needs an ignition feed to it. (doubled up with the wire for the lambda, which is fed from your switched live)
what year is your car?
jaggers12
my car is a f reg and the engine is out of a w plate 306 . ive got the grey airbag and the grey lambda connected to the switched live
thanks andy
Edited by jaggers12
jaggers12
also if it helps ive got 12+ on pins 2 8 11 and 15 on the double realy
so have you connected the switched live or not?
jaggers12
Ive connected my switched live (2a) to cc1 and 123 which are both grey wires on the 19 pin plug
and is there continuity from there to the relay?
jaggers12
im not sure and its a bit to cold for me to go back out and double check . I wouldn't of thought I would of had the 4 lives at the double relay if that was the problem.
also this engine was previously in a phase 1 and had been running
the 4 lives are permanent.
jaggers12
oooooohhh im gonna have to pull all the plastic covers of the loom in the morning and pull it all out
thanks
Just buzz from 2a to pin 14, make sure you have it connected to the 306 loom properly.
Did you unplug it from one car and fit it into another? if so you need to check that both sides of the brown lugs match, the location of some wires did vary.
jaggers12
if I power pin 14 the fuel pump bursts into life . no had to change where the phase 1 loom joined the 306 loom a the phase on only has 1 brown plug
dobboy
Did you remember to short the oval plug out?
jaggers12
the inertia switch ? that's been bridged
dobboy
Yeah, I'll dig out the wiring diagram i did on monday for you if you haven't had any joy by then
jaggers12
that's awesome thanks. im gonna have another mess with it tomorrow. just seems like everything is going wrong with it at the moment
dobboy
No worries, honestly it's very easy. Only need 3 or 4 wires to get it running.
jaggers12
So im following my switched live wires one goes up towards the ecu guessing thats for the lambda and the othe goes to a grey plug think this is for the airbag is this plug supposed to be plugged into something
jaggers12
Also what is pin 5 on the double relay suppost to connect to as mine goes to the 19pin plug
jaggers12
All sorted☺
dobboy
Here's how i wired mines (if you can zoom enough to see the file). The red wires are new wires i ran from the OS footwell/one of the brown plugs, out through the NS bulkhead, done in a flexi conduit.
Any queries just ask, (but it seems like a lifetime ago now)
