Kezzer30
What Sensors Are These Etc
Kezzer30
I'm wanting to learn as much as I can about my 1.9 and there's a few things I'm not sure what there are etc
what are both of these located through the gap of the alternator and inlet manifold .
this sits on top of gearbox and this has not being connected on mine for I assume all the time I drove it lol
these two are located round the back of the thermostat cheers
j_turnell
Oil pressure switch and sender top pic, second pic is the reverse light, and bottom is water temp gauge and warning light.
Kezzer30
Thank you buddy , the blue plug on side of thermostat is the water temp sensor and the plug sat on bottom of sump is the oil temp sensor is this correct ?
Yep - coolant temp sensor for the ECU and the oil temp sender for the dashboard guage :)
