Slo
Turbo Standard Psi?
Slo
What is the standard operating psi on the 2.0 turbo? Searched for ages and cant find the answer
Henry Yorke
It is only 0.5 bar IIRC, though I think there might be a small overboost function on the 2.0T a bit like the 405 T16. Not 100% sure as it is a while since I have had a look.
I've seen 0.65 bar before. But I think it varies slightly between 406/Xantia engines and XM/605 engines, as does the compression ratio.
Slo
Thanks for the replies guys.
Ive just read on a random forum it runs at 9psi :lol: Im definately taking that with a pinch of salt
Although the same guy, in the same long post actually, mentions that the bog standard turbo will last a couple of months tops if its pushed any more than standard psi
and that it heats up the coolant dramatically faster than it already dramatically heats up normally.
Edited by Slo
9 PSI is about 0.62 bar so that's probably about right.
I ran one at about 13-14 PSI in an XM for about a year! In the end the rest of the car fell apart but the engine and turbo were still fine.
Slo
Aye they are good strong engines and underated in the luxury barges.
At 13-14 psi was the difference dramatic from bog standard? Any massive heat rises at that?
Subjectively it felt about the same as a 3.0 V6 XM so it was a pretty big difference. Coolant temps were no different, inlet temps I have no idea but the XM does have a massive radiator and intercooler.
