erbs
Bleeding Brake Issue
erbs
Ok here is what i have done
Replaced MC
Replaced all the pipes and flexi's for brand new
Replaced Rear brake cylinders and new shoes
Used 306 calipers on the front with new pads
Brakes feel spongy, bled so many times now,not sure if the front calipers are an issue
any help please??
have you adjusted up the shoes?
erbs
yes coz when i put a lot of effort in pushing the pedal the rears lock up, i was thinking maybe the 306 calipers have a bigger piston size and and can cause not enough push
could be knackered compensator.
erbs
updated
Just been to my garage to try and find what the prob is
what i have done is run the engine and one foot is hard pressed on the brake and the other revving
what happens when i do this i feel a dip in the brake pedal once revving, any advice will be very helpful
also discovered why the speedo did not work too, was not seated properly in the gearbox :lol:
i managed to fix something today :D
Edited by erbs
Slo
are you using one of those gunson bleed kits? It's the only thing that would bleed mine properly. spongy=trapped air in the system
2-Pugs
Have you checked for leaks from any of the joins or unions?
erbs
i used a bleed kit but now everytime i try and use it, it pops off the reservoir, it maybe just air in their still as it was a complete rebuild of the brake system
yes i have, got no leaks anywhere,still the same amount of fluid and their is no loss, just seems a little odd.
Mattr5uk
Have you tried cracking off the unions on the master cylinder and checking there's no air trapped there? The vw/skoda/audi suffer with air getting trapped there but they have a bleed nipple fitted to the master cylinder.
erbs
funny enough i did that today, only a bit of air came out of the redundent union, still no change thou, must be more in there somewhere
Edited by erbs
Plumbob
I used an ez bleed only today on my car and it was fine. I only put 15 psi in the tyre rather than 20 as you could "just" hear a tiny bit of leakage on the reservoir adaptor cap when it was 20 psi. It worked perfect, went round the car twice.
It wouldn't be anything to do with having the handbrake on when you're bleeding would it? not 100% sure if it would make a difference for you? For drums maybe not...
Are you sure its not just the rear wheel self adjusters playing silly games as Welshpug implied earlier? Very common and gives a rubbish pedal with too much travel no matter how much you bleed it as you're having to take up the slack with the first part of the pedal travel.
spot on Anthony, I'd start there, slacken the cables right off, adjust the shoes up till they just rub then try again.
erbs
Another update
Sorted!!!!
the rears needed adjusting by quite a bit,now when i start the car up there is minimal travel in the pedal
and all the brakes work equally
Thanks guys
