Dangerous Dave
Stuck With A Misfire
Dangerous Dave
Hello,
Right i have pulled a 1.9 turbo diesel lump out of my 205 gti and put a stock 1.9 petrol back in the car is up and running.
anyway heres the problem (i have looked but there is no answer in the search bar) i have a misfire at 2500 rpm to 3000rpm ive done the normal when replacing the engine.
new oils engine and box
new plugs
new leads
new coil
new rotor arm
new dizzy
new fuel relay
new ing amp
new fuel filter
new temp sensor
2nd hand sad
the list goes on
also fitted a known working afm from a member on here..
this past week i have cleaned all connections/earths agian an looked for any air leaks/splits in the pipe work. ive had the car in the garage to have the mix set up so that all good.
there is one thing when you rev the car the red rad light flickers on around the time the misfire starts any ideas?
Thanks Dave
When you fitted the new ignition amp did you use thermal transfer paste on the heatsink?
The rad light flashing on can be caused by interference from the HT leads, are they clipped in place or just hanging loose?
Dangerous Dave
yes i used the paste when i changed it over, an the leads are clipped in like they should be.
im thinking i should take a match to the car? lol
ATK
i had a misfire issue (albeit only when cold) and it was the fuel pressure regulator
