Telf 224 2 Cars Posted January 5, 2015 Hi all, Had a bit of a drama earlier! I was driving along a unlit country road this evening when my lights failed. I pulled over and after some investigation noticed that if I released and locked the fuse box the lights came back on. I found this plug on the fuse tray burnt - does anybody know what it powers apart from the lights? I think the wires to the 2 plugs in front (as you look at it) had been putting pressure on the contact causing it to vibrate and arc-having untangled them all it does sit a lot better. If there had been excess current being drawn then I would have expected a fuse to blow but this hasn't happened. Any help would be great! P Share this post Link to post Share on other sites
jackherer 543 Posted January 5, 2015 What headlight bulbs do you have fitted? Every time I have seen this in a 205 it was because higher wattage bulbs were fitted without using relays. I knew it was going to be the headlights as soon as I read the title... 1 Share this post Link to post Share on other sites
Telf 224 2 Cars Posted January 6, 2015 Hi jack, I have no idea what bulbs are fitted - I don't think I've had to replace them since I bought the car. I don't know where im going to get a new plug without visiting the scrap either. Is the red wire the supply from the battery- I'm presuming so because of the thickness? Cheers Paul Share this post Link to post Share on other sites
welshpug 1,646 Posted January 6, 2015 no, the main live feed is the two brown wires. Share this post Link to post Share on other sites
Anthony 1,002 Posted January 6, 2015 The two thick brown wires you can see on the left of the picture is the incoming constant feed from the battery. I think that I've still got a butchered interior loom in the loft somewhere so if you get stuck I'm happy to send you the yellow plug if you can't source one. I think they're all mostly still available new from Peugeot/Citroen though (part numbers in someone's signature - Ryan maybe?) but not sure on minimum order quantities. Share this post Link to post Share on other sites
jackherer 543 Posted January 6, 2015 I've probably got a spare plug on an old loom and I've got some new terminals and a proper crimp tool too so you're welcome to pop over as you're local. You need to find the cause too, I'd definitely check the bulbs, this happened to my friends 205 and he'd owned it for a while before there was a problem caused by bulbs fitted by the previous owner that he knew nothing about. Share this post Link to post Share on other sites
Telf 224 2 Cars Posted January 6, 2015 Ok, so I've took the plug out- the plastic was ruined around the terminal, the actual spade tag was completely loose rattling around the connection. It looks like its been making contact with the blue wire next to it. As I need the car working until the weekend I've insulated the suspect wire and squeezed the spade tag back together so it fits properly then refitted the rest of the plug. The lights are working and manipulating the wire no longer causes them to turn off. Jackherer I will definitely drop round if that's ok- would you be free at the weekend? The repair shouldn'tt be a problem I'm a avionic technician by trade - possibly the worse example of my work ever in that picture but no resources to fix it at 7pm on a rainy Tuesday night thanks all Paul Share this post Link to post Share on other sites
jackherer 543 Posted January 6, 2015 I'll probably be here, I'll PM you my details. 1 Share this post Link to post Share on other sites
Telf 224 2 Cars Posted January 13, 2015 Just like to say thanks to Jackherer - 1 for being completely correct- I did have a massively overwatted bulb 90/130W ! 2 for giving me a plug 3 for leading me the tool to fix it Cheers very muchly! paul 1 Share this post Link to post Share on other sites
jackherer 543 Posted January 13, 2015 No problem, thanks for the beer Share this post Link to post Share on other sites
Tom Fenton 1,536 Posted January 14, 2015 Nice one guys, that's what the forum should be about. 1 Share this post Link to post Share on other sites
