jonb_5
Wiring Help
jonb_5
Hi,
I have been removing some unused wires from the 205 this evening and have a couple which I can't seem to trace in the manual.
Firstly, 2 blue wires, labelled 52 coming from what I would say was some sort of sender on top of the gearbox, any ideas?
Second, on my coil I have 2 wires connected to the negative terminal. A purple wire labelled 3 and then 2 green wires from one connector, a light green colour. 1 goes right the way through to the instrument binnacle and the other dissapears down into the depths on the engine.
Any help in identifying these would be appreciated.
Jon
52 and (IIRC) 52a go to the reversing light switch on the gearbox.
The coil negative terminal is connected to the ignition amp and the tacho.
edit: It is 52 and 53 for the reversing light switch.
Edited by jackherer
jonb_5
Brilliant, thanks for that.
Jon
